Hi to all.
I am currently designing an input filter for a off-line switcher. The
switcher is a tinyswitch 278
running at about 11W. 220Vac to 13.8Vdc , 800mA.
When designing the filter , do you design for the average input
current , or must you design
for the peak input currents you see when the bulk input cap is "topped
up" every 10mS.
There will be a big difference in component (inductor) size depending
on which way you go.
The average current is only a few hundred mA , where as the peaks are
about 1,5A.
If desighning for the peak currents of 1,5A the filter components are
bigger than the whole
rest of the supply!!!
If this is the correct way to go than that is fine , but I don't want
to design for something that
is not necessary.
Cheers
Robin
up" every 10mS.
about 1,5A.
is not necessary.
Cheers
Robin
