Hi all,
Can anyone tell me if there is a way of determining the value of an
unmarked SMD capacitor? Silly question, I know.
The device is about 1.5 x 1.5 x 1mm, it's yellow. I can only imagine
the value could be guessed at by it's physical size.
It's out of a series LRC oscillator circuit for the fill sensing in a
Fisher and Paykel IW708 washing machine (so getting a circuit diagram
is probably not possible) and its o/c. The circuit is a 5V supplied
74HC04 and the oscillator wouldn't until the cap was changed.
So far guessed at .22uF, but this is too large. Trial and error seem
to be the best bet at this point. The L goes up with water level, as
does the frequency of the circuit, so I'll have to drop the
capacitance value as it's overfilling. (i.e. correct frequency never
reached)
Any circuit advice would be appreciated, I've already had all the
advice I need on F&P washing machines in general. It's either fix it
or buy a new machine, and fixing is the cheaper option at present.
I had the darn thing fail three year ago with exactly the same
symptoms, got the F&P man out for a total of $270 to change out the
control board. I kept the old one, with the identical fault (bad batch
of caps?) and it'll be fixed as well, I hope.
TIA
- Rob.
reached)
TIA
- Rob.
