Smartcard reader project
Joe G \(Home\)
Hi All,
I would like to develop a simple contact smartcard reader to ISO7816...
with a little bit of security... using the Philips TDA8009 IC and a micro.
What cards would you recommend and where would you get them from in small
volume.
What protocols/standards would you suggest with a little bit of security.
Thanks in advance for your suggestions amd info.
Regards
JG
Rafael Deliano
Are you sure you need that IC ?
http://www.embeddedforth.de/temp/chipkarte-hw.pdf
Sorry text is in German, but circuit should be obvious.
The official protocol for "smartcards" with processors
nominally requires a UART. But as transfer is halfduplex
its easy to do it via a software-UART. You probably will
not use that type of card anyway.
With simpler/cheaper cards like SLE44xx its bitbanging.
That probably excludes repackaged I2C-EEPROMs.
Do you want to store data or only have a "key" ?
For reading unprotected, but writing protected by PIN:
here in Germany mainly SLE4442 ( 256 byte ) and SLE4428
( 1k byte ) are readily available for small volume applications.
Try google & ebay for sellers.
MfG JRD
martin.shoebridge
You can buy these commercially from £10 or so, ready to go + free software.
typical cards are FUN4, Titanium2 etc.
