Travis Evans
Since some people are concerned about the activity level on this
newsgroup, I'll post something.
Something that happened last night made me curious. My flashlight
suddenly would not turn on when it was working fine just a little while
ago. If the batteries were low, the lamp would have dimmed, but not
suddenly stop working altogether. After reading a message here some
time back about the life of flashlight lamps being very short, I
figured the lamp had burned out since I use that flashlight nearly
every day, often for an hour or more at a time. I was actually
wondering how it had lasted for so many months with that much usage
(likely because I use AA NiMH rechargeable batteries instead of
alkaline due to short battery life--the voltage of rechargeable
batteries is slightly lower).
The lamp evidently did fail--there is no continuity on the lamp contacts
(there is with a known good lamp), and putting in a good lamp made the
flashlight work again, and the bad lamp still does not work in a
different flashlight. (In case it's important, the markings on the
lamps read "PHILLIPS KPR102 2.4V 0.7A H K 1K3".) So that makes me
curious--if the filament appears intact, what is it that breaks the
circuit?
I've seen this happen in mini-Christmas lamps as well--they stop
working, but the filament doesn't look broken. I figured that with
Christmas lights, the shunts that are designed to short out the lamps
when the filaments open may sometimes short before filament failure,
but a flashlight lamp doesn't have a shunt.
An unrelated but interesting thing that happened last Christmas--a lamp
on a set of lights we had hung inside the house was accidentally
broken. The rest of the string continued operating, and it was a while
before I finally replaced it (probably would have been safer to have
replaced the broken lamp immediately, I admit). But on the broken
lamp, the filament was completely intact! Wouldn't air exposure to an
operating filament burn it up immediately? So I guess maybe the shunt
somehow shorted before or during breakage, extinguishing the filament
before that could happen.
circuit?
