mook johnson
gents,
I'm looking for a high sped, low capacitance mosfet in a package the
size of a to-92 or smaller than a SOIC-8 with the following characteristics.
application:
Attached to a 1:1 push pull transformer with 5V on the CT to generate ~
10V p-p on the output. This means the switching transistors will see at
least 10V when the other one is one + leakage inductance spike.
Each transistor will turn on between 25 and 50nS each. The peek current
during each pulse will be ~ 300mA
When both transistors are off, it is desired that the reflected
impedance from the secondary is high hence the reason for low
capacitance mosfets.
The MOSFETS I've seen that fit this description usually have very
voltage. (Vds ~7V)
Wondering if you guys know of a higher voltage "RF" mosfet for an
application like this one.
thanks
application:
voltage. (Vds ~7V)
thanks
