Bob in PHX
To All,
I have an interesting problem that I need to solve. I have an older
electronic blackjack machine that has blown the coin hopper pay out circuit.
No schematic of the board is available and the pcb has a 25 cent sized
burned clean through it.... The good part is that I found a chip that puts
out a 5 volt signal when the "jackpot" is hit and the coin hopper needs to
start. This 5volt signal stops when the jackpot has been paid.
I was thinking that a simple relay would work, but then I worried about
pulling to much amperage out of the chip, which by the way is some sort of
specialty chip, thus I don't know what the chip can stand. So, I figure that
I need some sort of opto isolator chip that has a very small amperage draw.
This chip would allow me to use a separate power supply to trigger the
relay, with say a 2n3904 transistor.... I just don't know what chip to use
that would isolate the 5v trigger lead from a separate 5v powered circuit.
The two circuits would not share a ground.
any ideas??????
Bob in phx....
any ideas??????
Bob in phx....
