Brian Wood
Learned ones:
I posted this request to another (non-usenet) forum and was referred to you
by a friend in that forum.
I did also cross-post this in alt.energy.homepower, at his suggestion. When
I posted there, I discovered that I am using a usenet account established by
my nephew several years ago. The account is his name (Brian Wood); my name
is Dennis McKim and I live in western Colorado. Sorry for any confusion that
causes...
It is difficult to present my current 'daydream' in a reasonably short post,
but allow me to try: I plan to purchase a recumbent tadpole-design tricycle
(see www.catrike.com/road.htm for photos). "Chain management" is often an
issue for recumbent trikes, and idler pulleys are often used to control the
chain as it passes under the seat. I enjoy riding before sunrise and after
sundown, and will need reasonably powerful lights on my trike. I plan to
install a 14.8 volt Li-Ion battery pack, with a (nominal) 12 V lighting
system (HID or multi-LED headlamp and tail lamp, and a 360° amber strobe
light mounted on a pole behind the seat).
I wish to consider a small 12 V generator driven by a toothed idler pulley,
mounted low behind the seat. It will serve for chain management and power
generation. My front chainring will be 32-tooth and the rear gearing will be
an internal hub, so the chain velocity will be constant (no rear
derailleur). My normal pedaling cadence is 80 RPM, so the 16-tooth idler
pulley will be driven at ~160 RPM. I need an output of only 3-4 amperes, and
might get by with only 2-3 amps. I don't need to power all of my lighting
exclusively from the generator; I need to keep the battery charged and then
extend its run-down time after dark when I turn on all the lights.
Is it feasible to try to construct a generator, using rare-earth magnets and
copper wire, that will generate 15-18 volts, and have a package something
close to the size of a can of soda pop (2-2½" diameter, 4-5" long)?
My research to date finds many designs for homemade generators, but all of
them are large diameter (6-10 inches). That is great for wind turbine
projects but not suitable for my dream. I've heard of using brushless DC
motors as generators, but all that I can find operate at very high RPM.
There are dynamo hubs available for bicycles, but they all generate 6 volts
and I am committed to a 12 V system. There are "bottle type" generators for
bicycles that drive against the lateral surface of the rubber tire, but I am
(at least for now) set on designing something driven from an idler pulley.
What do y'all think? Totally feasible? Impossible? Somewhere in between?
Just to keep the discussion on track, please understand that I am also
investigating the options of solar power to charge the battery, and of using
a larger battery and "home-charging" it. My purpose for posting here is only
to inquire about the technical feasibility of constructing a (very) small
12V generator being spun at only 160 RPM.
Thanks in advance,
Dennis
causes...
Thanks in advance,
Dennis
