http://www.maplin.co.uk/p/maplin-sma-crimp-plug-rg58-mm55k
I have something like the above. Not pictured on the above link, is a sort of short length of metal tube that seems to slide over the knurled part, with a tad of clearance.
I stripped back my coax cable & was able to assemble everything okay; I fitted the short length of metal tube / "sleeve" supplied with the connector, over the cable first then slid it back so that it gripped the braid of the coax between itself and the knurled part of the connector.
I found the inner insulation of the coax fitted nicely inside the knurled part, so that it directed the central conductor straight into the pin without it shorting to the outer.
Now having never met this style of connector before.. I've done nothing more.
I have a standard electrician's crimp tool, and the maplin guy told me to use this to crimp it. He didn't say where to crimp it lol.
It seems to me that if I did hit it with the boggo sparkies crimper, it would make a royal mess? crumple everything? short the braid to the knurled part and then short the knurled part to the inner, before metal fatigue just destroyed the whole lot? Might as well ask a lion to bite it?
Do i need some kind of special tool here or should I attempt to solder it, or is it really ok to crimp it with a standard crimper a la 6242Y?
