You can buy the sleeve bearing fan to do the same air flow.
Its just that in your purchasing , you havent found them.
OK, I know the brands I have tried and tested, perhaps you can identify the
one you are referring to so I can try them as well.
Of the models that I have tried, two different manufacturers have had both a
bushed and a bearing model to choose from, the motors were the same wattage
rating, the fans and housings were the same mold and material, only the
bearings, pricetag and the airflow were quite different.
The price was a difference of maybe 15 percent, and the airflow was better
by greater than that amount. I have removed the cover from the fans and
lubricated them with a variety of oil or oil like compounds and although
this has improved the performance of the bushed units for a period of time,
the result was that as the lubrication deteriorated, the bushed fans dropped
in revs and airflow.
I am using these fans 24 hours a day, seven days a week at 100 percent duty
cycle as the circulation fans in a temperature controlled oven at 38 degrees
C and they are mounted vertically so the shaft and airflow is in a
horizontal direction. If the axis of the fan was mounted pointing up or down
then the fan bushes may wear differently. Failure mode on the fans I have
tried has been due to increased wear in the bush on the bottom side where
the weight of the shaft is supported. They wind up with an oval hole that
increases drag and although they can be run for a while by lubricating and
turning them upside down and wearing against the other face of the bush,
this will only give a little service until I am able to return to replace
the bushed fan with a decent ball bearing model.
Quite frankly, I'm only reporting on my experience and my customers are
happy to pay me a fortune to replace fans!
Hope this helps,
Peter
