Skin effect a problem for inductor?
Hello
Please could you tell if an off-the-shelf inductor will be ok for our requirement?
Eg will this inductor be ok….
2209-RC (47uH from Bourns.com)
http://www.bourns.com/data/global/pdfs/2200_series.pdf
It is the output inductor on a half-bridge smps.
It will see a Max current of following
Average current = 4 Amps.
RMS current = 4.4 Amps.
Peak current = 6.7 Amps
Ripple frequency = 111KHz.
The di is quite high (5.1Amps)
i.e. 5.1 Amps at the switching frequency (111KHz)
We need a high ripple in the inductor to improve our transient response.
Will an off-the shelf inductor with a single winding be ok, or will we need to custom build, with multiple strand conductors to mitigate skin effect?
I think the most important detail is that the inductance at the rated current is only about 30uH.
A larger core, and biflar windings or stranded wire would probably improve things, but it all comes down to cost/benefit.
At 100khz, the skin depth is a little over 0.2mm in copper wire. So the ultimate would be to use 0.4mm stranded wire.
If the smps will be in continuous mode, there will be a fairly large DC component to the current through the inductor and skin effect will be less of an issue.
Skin effect will not be a problem at 111kHz. Core loss may be high. I took a wild guess and assumed it was something similar to a MPP core. Working backwards from the Bourns data, I get something similar to a Mag-Inc 55206-A2 core with 26T, 21AWG. The core loss curves on the Mag-Inc website (http://www.mag-inc.com/products/powder-cores) shows about 2.4W core loss. The skin effect will make the effective resistance about 15% or 20% more (for the AC component of your current) so youv'e got only about 0.6W of copper loss.
Note - My core guess could be way off but, in general, with that amount of AC, core loss could be dominant.
Thanks,
Though i'm mystified as to why people use multiple strand windings now, as you appear to confirm that skin effect is not that much of a problem.
For example, i worked at a television company, and they had three a strand secondary on their 16V(out), 33W, 70KHz, DCM 230VAC flyback.
So why were they bothering to use three strands i wonder...if skin effect isnt that bad?
