Single to three phase... sort of...
Hi.
In what conditions would this make three phase from single phase ?
Feeding single phase at left, using the right ends as three phases for Wye motor with neutral center. ¿?
That is 2 phase or split phase for a 1ph motor, the common way to generate 3 phase from 1ph is a RPC, (Rotary Phase Convertor) using a 3ph motor and series of caps to produce/generate the 3rd phase, the other two being the 240v 1ph conductors.
There is also the commercial Phase Perfect which does a similar thing, but electronically create the 3rd phase.
M.
In what conditions would this make three phase from single phase?
Great question, but I don't think that's possible for 3 phase since the reactive phase shift can't be more than 90°.
Yes, 2 phase power circuits (mostly obsolete) are 90° apart.
Single split phase circuits are 180° apart which is essentially the opposite polarity.
And 3 phase needs to be 120° apart.
Another way to derive 3 phase from single phase is to use a variable frequency drive.
