Captain Midnight said:
Their is no explosion in a properly operating internal combustion engine.
The fuel merely heats the air. The expansion of the air pushes the piston.
An explosion called detonation or knock can put a hole in the piston. Some
engines require higher octane fuel to keep knock from occurring.
That seems to me to be a misleading description of the principles of an
internal combustion engine. The fuel is mixed with the air in a very
carefully controlled ratio, highly compressed, and is then set light to,
either by a spark in the case of a gasoline engine, or by self ignition from
the rapid heating of the mixture during compression, in the case of a
diesel. It burns or combusts, and what comes out of the exhaust, after the
burning, is not air, but a fully reduced residue of the burning process. The
burning of the mixture under such intense pressure, in what is essentially a
fully contained space, takes place at such speed, it would usually be
considered to be representative of a controlled explosion. Detonation knock
is normally as a result of the timing of the ignition source not being ideal
for the engine in question. The detonation process should be started just
before the piston reaches top dead centre, so that by the time the burning
has spread fully from the initiating point - ie the spark plug - through the
entire mixture, and is thus at its fiercest, the piston has rolled over past
its point of being momentarily stationary, and is just beginning on its way
back down the cylinder. The rapidly burning ( exploding ? ) mixture will
then deliver maximum thrust to the piston, driving it down the cylinder
bore. If the mixture starts to burn too early, it will reach maximum energy
output before the piston has reached the top, so will oppose the upward
movement of the piston, which is still occuring, leading to the
pre-detonation knock.
Maybe it is just semantics, and some may disagree, but that has always been
my take on how an engine works, ever since I was first rebuilding them as a
kid, because I couldn't afford repair shop prices !!
Arfa
