Single-Layer PCB Design Software?
Z
Zucker
Does anyone know of a good program that will allow me to create and
autoroute simple single-layer PCB designs?
I've tried products like PCB123, which seem to force me into using atleast
two layers.
Adam Aglionby
Eagle free for small non-commercial projects:
www.cadsoft.de
There are a set of design rules, downloadable somewhere on site, that force
a single sided autoroute.
HTH
Adam
Bill Jenkins
two layers.
Look at www.ezroute2000.com this will allow single side autorouting.
Bill Jenkins
Tim Auton
two layers.
If you're routing manually just don't select the layer you don't want
:) If autorouting, set the cost of the layer you don't want very high.
Even on a single sided board you'll probably need two layers - even if
the component-side layer is just 3 wires. If that makes sense...
Tim
Jan-Erik Söderholm
You don't need anything extra, just tell Eagle not to use
one of the sides what autorouting...
Jan-Erik.
Adam Aglionby
Thanks, remebered afterwards that Eagle would allow you to just switch off
all but one layer.
BTW for the original poster , inkjet printers will make a useable to mask if
printed on to ink jet compatible overhead tranparencies.
Adam
JeffM
remebered...that Eagle would allow you to
just switch off all but one layer.
Adam Aglionby
That's not how it's done.
That's just for viewing (or printing to PnP).
You were correct the 1st time when you talked about design rules.
As Auton said it's about the "cost" of a layer
which YOU specify in the design rules.
The Autorouter uses this value to give results like what you desire.
If you set the cost of the top layer extremely high,
there will be few runs routed there
and you can go back in and edit the board
to put jumper wires where it wants to put traces.
IMO EAGLE's autorouter is pretty bad.
I advise routing by hand those runs which look hard to connect
--especially power buses--
and designing in jumper wires (top side) as necessary.
After that, turn the autorouter loose on it.
Jan-Erik Söderholm
I think it is.
When autorouting, you can tell Eagle what primary direction
you want each side to have ( "-" or "|"). You can
also select "none" for one side, which tells Eagle to not put
*any* traces on that side.
Yes and no, that's other settings in another part of Eagle...
Note !
I'm using the freeware version of Eagle, but I don't think
this would be different in the "real thing"...
Note 2 !
I don't have Eagle "flying" right now, so this is from my
memory, but I'm *pretty* sure it's how it worked last time.
And I'm 100% sure that I have autorouted single sided boards
without installing anything else then the base system.
Jan-Erik.
Adam Aglionby
Jan-Erik Söderholm said:
I think it is.
Note !
Note 2 !
Jan-Erik.
Another great thing about Eagle is the amazing support, even for the free
users, thanks to Orlando over on eagle.support.eng for
this answer in less than 10 mins from asking it :
layer as N/A and route. If the design is simple you've got yourself a
routed single-sided board.
hth
orlando <<<
Adam
MrWizard
all but one layer.
Adam
Hello, PCB123 will allow you to autoroute on one layer no problem.
Double-click on the autoroute button and then select only one layer
then run the router... A question though is why do you only want to
use one layer? If you have more questions please don't hesitate to
contact us at 1-800-228-8198 or support@pcb123.
Todd
AkA MrWizard
