I'm new here, but I hope someone can help.
I have a single cell Li-Ion battery that has a protection PCB built into it, but I would like to build a little more protection into the circuit to cut it out of circuit before the built in protection cuts in, or I'll have no way of charging it again.
So I was thinking of using a PFet high side switch and a micro power voltage monitor chip to drive it. If I used one with a reset pin then the on board micro would be able to reconnect the battery to charge it again.
Would that seem a sensible solution? Or is there a better way?
The device will be powered from the battery, but will be plugged into USB to charge it.
My thinking was this:
Device slowly discharges the battery while it is not in use - sleep mode.
When the battery gets to the trigger voltage the Fet disconnects the battery - meaning only self discharge now drains the battery.
The device is plugged into USB to charge - powering up the circuity and re-connecting the battery to charge it.
If the extra protection wasn't there, the circuit in sleep mode would just drain the battery down to the built in threshold and then it would never be able to be re-charged?
Thanks,
G
Thanks,
G
