Simpson 360-2 DVM problem
Steve
Does anyone here have experience with these?
I've had a Simpson 260 on my bench for years
and just picked up this 360-2, which is a DVM
in the same case as a 260.
The problem is its over range on all settings.
Probably the input circuit. Has anyone out there
had this problem? If so, what was the fix?
Steve
W
whit3rd
                            Steve
Inputs are usually protected by fuses, and overrange
readings might mean the fuse is bad. Meter failures
also result from dirty/broken switches, worth checking.
(always check the obvious things first).
The last time a meter failed on me, it was a speck of
something conductive shorting the selector switch.
