If you are "testing" woofers, you probably want a nice sinusoidal output with almost zero harmonic distortion and good amplitude stability as a function of frequency. What you need is a
Wien bridge oscillator, said bridge having been developed by Max Wien in 1891. If you can find one, the
Hewlett-Packard 200CD audio signal generator is an excellent choice. Or, if you want to
roll your own, I have attached the original schematic from William Hewlett's 1939 U.S. Patent. If you can find the parts you need (a dual-ganged capacitor or dual-ganged resistors) the Wien bridge oscillator is simple to build... oh, you will also need a small incandescent light bulb whose filament is used to provide negative feedback for amplitude stability.
If you follow the "roll your own" link above, Ramon describes a 1 kHz to 10 kHz oscillator. It will take some design effort to lower the range to 10 Hz to 100 Hz (probably need
two incandescent lamps wired in series)
, but his circuit only uses
one potentiometer and
NO variable capacitors.
