As my diagram shows, the use of a parallel resistor is used to divide the circuit, but does the resistance of the circuit change due to its inclusion?
I would have to deduce that it will effect the circuit at least a little bit. Is a the series/parallel rule or should I do a total the current and reduce the volts trick?
