Scott Wiper
This curcuit apparently does not need inductors for C2, C7 and C8.
Apparently ZI went to Carleton Univeristy and asked a graduate student who
is specialising in switching type power supplys. He said to me that a series
inductor for the above caps is not required because the final transitor I
will be useing a power darlington pair known as a 2N6284. This apllies to Q2
and Q3 and well. The 2N6284 has built in base/emitter shunt resistors shown
on Q5. This should absorb spaikes on C2 and C7/8 in This schmatic. The
2N6284 has a gain of typical 2000.
Here is the datasheet:
http://www.onsemi.com/pub/Collateral/2N6284-D.PDF
I have dicaded to use this transistor because it's high current gain. I am
building the and thanks to the Univerity I can test with a scope to see if
their is a spike on C2 # 120/50%Duty cycle. I am hoping this Transistor can
switch and the frequency I have set between 120 and 144 HZ. I have resplaced
the two pulse drive Transitors with TIP41C meduim power transistor that are
NPN so the 2N6284 will switch at 180 degrees out of phase with the Q outputs
on U2A and U2B.
Should I place a varible inductor in series with the voltage stablising caps
if I exeed 1.5A at 13.8VDC and 1.5A at 5.3VDC to remove spaikes or ripple
during the switching? I have inductors that can be adjusted from 60mH 360mH.
Note I will only 1.5A at 12VDC (Panel lights and fans) and 2.5A at 5.3VDC
(LED indicators and all logic IC's including total hours under power.)
Here is the schmatic: (This image is non-interlased it should be clearer to
view.)
http://www-travel-net.com/~swiper/switch.gif
Express pcb sheeet file
http://www-travel-net.com/~swiper/switch.sch
on U2A and U2B.
view.)
