I have a 13.8v, 30 amp power supply that is over current protected, but not over voltage protected.
Am I correct in thinking that a simple zener diode across the outputs, and an in-line fuse is all I'll need to have a crude, but effective over-volatge protection circuit?
If I use a zener of 14.4v or there abouts, if voltage exceeds this level, the zener will breakdown and short out the PSU's output, and blow the fuse.
My question is, for a 30 amp supply, what zener will I need to survive the time it takes to blow the fuse, considering it will be drawing 30 amps approx.
I hope I'm making sense
David
David
