Hi, guys.
I have been developing gad detecting system with Arduino.
My O2 sensor is 4OXV CiTiceL Oxygen sensor.
http://www.ebay.com/itm/UK-CITY-4OX...0883143&pid=100034&rk=1&rkt=2&sd=181596912854
In theory in normal air which is 20.9% oxygen the mA coming out of the sensor should be around 0.10.
The 4OXV is basically a current generator. All you need to do is to put a load resistor across the 2 sensor pins, measure the volt drop across the resistor to determine the current flow. This current flow is proportional to oxygen concentration.
I put load 100 ohm resistor across the 2 sensor pins, the output voltage will be around 10mV.
So I need simple millivolt to 5V amplifier to read this value with Arduino.
Is there any built-in breakout board?
(I have found the Sparkfun OpAmp Breakout board - LMV358, but this circuit is AC coupled and is therefore not suitable for use with our sensors.)
Thanks.
Thanks.
