Simple inline audio bass boost circuit ?
Marcel Gonzalez
I would like to take a line-level audio signal and boost the bass frequencies
before amplification. Any leads on a good circuit / kit ?
Marcel
John Larkin
Marcel
Two resistors, one capacitor:
in-------r1------+-----------out
r2
c1
gnd
The values depend on where you'd like the break frequency and how much
boost you'd like. Try r1 = 1.2k, r2 = 270 ohms, c1 = 1 uF, and play
from there. Use pots for the resistors, maybe, for easier fiddling.
Picky: this will actually attenuate the highs, not boost the bass.
Same thing, if you just crank up the volume to compensate.
John
John Woodgate
I read in sci.electronics.design that John Larkin <jjlarkin@highlandSNIP
techTHISnologyPLEASE.com> wrote (in <650k00phnq0pb65ophl7vjvfgmfd3b8t34@
4ax.com>) about 'Simple inline audio bass boost circuit ?', on Sat, 17
Jan 2004:
r2
c1
gnd
Those values are really too low. The source impedance, if this is
consumer or semi-pro equipment, can be 1 to 2 kohms. 10 kohms, 2.7 kohms
and 0.1 uF/100 nF might work better.
It gives 13.5 dB of boost at very low frequencies, which may be too
much. Increase the 270 ohm/2.7 kohm to get less boost.
That's all you can do, practically, with a passive circuit.
N. Thornton
Marcel
Why before amplification? Its much easier to put a cap in the nfb path
to give you bass boost - dont forget an R across it for dc and to
limit the boost.
Regards, NT
