Simple hall effect current transformer..?
G
Geir Holmavatn
I wonder if there exist simple current transformer solutions using hall
effect devices instead of bulky wound coils. I need to measure current
between 0 and 100amps flowing in 1-phase or 3-phase mains cables. The
units should contain an A/D converter with output to a standard bus,
like for example 1-wire etc..
Has anyone here heard about simple yet relatively accurate (+/- 3%)
current sense devices / solutions with digital output..?
Thanks for comments and info
regards
Geir
Jamie
Geir said:
regards
Geir
http://www.apcs.net.au/products/niche/hct016.html
something like that?
Dave Plowman (News)
Sounds like what you want is a clamp test meter. They work to that sort of
accuracy. They're priced from only a few dollars - but one with a data
output bus will be more.
I
isw
Geir Holmavatn said:
Check out F. W. Bell; they used to make Hall-based units good for up to
a few hundred amps.
Isaac
Indeed some neat products. The OP request for a digital output may not
be so immediately available but the following link points to an "easy
to embed" solution for in-system use. The 0->5V output can easily be
converted to a digital value by feeding the voltage into the A/D
converter of your favorite microcontroller.
ciscodsl
