Simple electronic switch for common ground loads
I have that model for a circuit used for IGBTs firing ( as in Circuit.1)
I want to energize A then B from micro-controller in a frequency about 50kHZ. with about 10 mA
I want micro-controller pin not to be loaded with more than 1 mA.
firstly I have intended to use "transistor as a switch" but I can not use it with common collector because the ground is common, so I have to use it as common-emmiter. but the problem is the output current is not greater than 3mA even if using 12V for transistor Vcc and higher current gain models (2n2222, bc247...)
Also I can not use optocoupler as circuit frequency is high (about 50kHZ)
I am searching for a solution. just fast electronic switch for common ground loads
Thanks in advance :)
