Hi all,
I decided to make a 24 hrs clock with IC 4026 and few logic gates. I drew the circuit diagram for that and have posted it below. Here I have given the output of the IC to the logic ICs so that I will be able to reset the min and hours after it reaches 60 and 24 respectively. The problem was that when the output of the IC 4026 was connected to to the logic IC (for example OR gate in the circuit) , the pins were left floating when there was no output from the 4026 ic which gave a wrong output. So I tried connecting a pull down resistor to the inputs, but adding these pull down resistos made the segments of the LED display ( segments that are connected to logic gate IC)glow dimmer than the others . So ,I need a solution to have my logic gates functioning properly without compromising the diplay's brightness. I have connected the output of the logic gates to the resemt pin of the ic 4026.Please help me in solving this problem lem. If you need any clarifications in the circuit, I will answer to those questions in the comments. Thanks in advance.
X and y are written to just denote those led displays segments with their pin.
I have not drawn the diplay's pin in order.
