OK, there are quite a few problems with that circuit.
1. You have connected a voltage source directly across the base-emitter junction of the first transistor. A base-emitter junction behaves like a diode. Look at the current vs. voltage curve of a diode:
(That diagram comes from
https://learn.sparkfun.com/tutorials/diodes/real-diode-characteristics)
See that in the top right quadrant of the graph, the diode current starts increasing rapidly when the forward voltage exceeds V
F, which is about 0.7V for a silicon device. So if you connect a voltage of 3.3V across a diode (or base-emitter junction) in the forward direction, a very high current will flow. This would damage the transistor.
The simple way to prevent this problem is to add a series resistor, as shown here:
http://electronicdesign.com/power/graphical-numerical-techniques-size-led-array-s-drive which discusses driving LEDs but the principle is the same for diodes)
The resistor, R
X, will have 3.3V on the left end, and around 0.7V on the right end, so there will be about 2.6V across it. Ohm's Law can be used to calculate a suitable value for R
X if you know how much current you want to flow.
Let's say we want 5 mA to flow into the transistor's base. Can you calculate an appropriate resistance for R
X?
2. You don't actually need the first transistor. But that lesson is an important one, and will actually apply to the second transistor, so don't ignore it.
3. The time constant of a C-R circuit with 10 µF and 10k is 100 ms. The question calls for a pulse width in the "milliseconds range". I take that to mean something like 5 ms. Can you change the value of C to get a time constant of 5 ms?
4. The second transistor is connected directly between VCC and 0V. This is a problem if it ever gets biased ON. Also, your output is taken directly between VCC and 0V, which means it will always be 3.3V and will be unaffected by the transistors.
Have a look at the three configurations for a transistor amplifier.
(That image is from
http://pdjinc.com/electronics_notes.html)
In each configuration, the transistor is connected across a supply voltage, but a resistor is also present. A resistor is normally needed when the output of the circuit needs to be a varying voltage.
A transistor is described as a current amplifier. In a common emitter circuit, the middle diagram above, current feeding into the base-emitter junction is amplified by the transistor and causes a higher current to flow in the collector-emitter path. In that diagram, R2 is used to convert the transistor current into a voltage.
One arrangement of Ohm's Law says that V = I R. So if R is constant (e.g. 10k in the diagram), this formula means that V is proportional to I. In other words, as the current through the resistor varies (due to the action of the transistor), the voltage across the resistor will vary in proportion. This means that the circuit has a voltage output, even though the amplifying device has a current output. The resistor converts one to the other.
If you omit the resistor, you have two problems. First, there's nowhere to take your voltage output from, and second, there is nothing to limit the current that can flow in the transistor's collector-emitter circuit. So for example, if the circuit feeds 10 mA into the base, and the transistor's H
FE (current gain) is 100, the collector-emitter current will be 1000 mA (one amp), which is too much for a small-signal transistor and will damage it.
I think you should have another try at the circuit.
You don't need the first transistor at all. You can feed your 0V/3.3V rising edge straight into the C-R pulse generator.
The pulse generator produces a positive pulse at its output. You need to convert this pulse into an output that normally sits at +3.3V but goes low when the pulse is positive.
