Simple circuit for RS232 > 12 bit DAC?
BR
Any schematics of this? I want to control only one motor from a PC. What I
need is high resolution control of velocity. Position isn't necessary. The DAC
will connect to the control voltage input of an H-bridge that has a built-in
PWM generator. The motor is a small Kollmorgen Servodisc.
Ben
Bob Masta
Ben
How about the parallel port instead? If you are running under
DOS (so you can write directly to the port) you can use a simple
R-2R ladder. You might need to buffer the digital outputs on
some ports if their levels aren't uniform on all bits. If you only
use the data out port you just have 8 bits, but you can also
use the control port to get another 4 if you're careful. (The
control port bits will almost certainly need buffering since they
have pull-ups.)
For the 8-bit version you can check out the LPTX driver
Help files for my Daqarta system at
www.daqarta.com/lptx.htm
This discusses using the port for analog in and digital out
as well as analog out, so read through for the DAC section.
Hope this helps!
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
John Fields
BR
Thanks Bob. I later realized how slow the serial port is. I forgot to check
this thread and started another. Looked around and found a 12 bit DAC such as
the MAX508. Should make it easier (I think) to get going since its interface
is a byte wide (8+4). But for starters it'll be an 8 bit DAC or a R-2R ladder
as the experiment may work with that resolution.
A control port will be used for the foward/reverse ports on the H-bridge.
Ben
BR
John, I made the mistake of considering RS232 as it's too slow. It'll be via
parallel port. What is an all-hardware solution? I'm using Quickbasic on an
old 133 machine. Just a bunch of loops to change velocity and will need to
edit those values frequently. If the experiment (fluid study) shows a result,
the program can be run again to repeat the result. It would be ideal to
manually control motor speed with a pot and ADC (looking for certain fluid
activity) while writing control data to disk, and then later playback the
data. But this would be a little ahead of myself at this stage. Bet Quickbasic
sucks for that.
Ben
John Fields
parallel port.
At 9600 bits per second you can accumulate 12 bits in 2.083ms, including
the overhead of the RS-232 start and stop bits and the wasted four bits
of data, so that's doesn't seem too shabby for a motor control
application!-)
For RS-232, basically a comparator or something like Jim Thompson's
MC1489,(just thought I'd mention it to save him a post!^) or one of the
zillion chips Maxim's got to change the bipolar RS-232 signal into a 0
to 5V logic signal, two 8-bit shift registers, a clock, some glue logic
and your DAC or R-2R ladder.
For the parallel port, it's a couple of HC373's or 375's and your DAC
or R-2R ladder and probably a little glue logic if you can't control the
registers with the port's control pins.
BR
application!-)
It depends on what you want to control. Might as well go with SPP being
50Kbytes/sec or better. The more throughput, the smaller the steps can be
during fairly rapid changes in velocity. I ordered a surplus S6M4H servodisc
"pancake" because it's a DC brushed type with zero cogging. It's design is
amazing to me.
http://kmtg.kollmorgen.com/products/product_literature/product_brochure/pdfs/KOL1037.pdf
They do have zillions and ran into a 12 bit DAC with byte wide loading, like
MAX508. Didn't know they made them. Maybe easier to use?
http://pdfserv.maxim-ic.com/en/ds/MAX507-MAX508.pdf
It's been a while since I've looked into this stuff and really need to move
beyond the CMOS 4000 series :)
Tanks
Ben
