Tilmann Reh
Hello,
I am looking for a simple but reasonably precise ramp (sawtooth)
or triangle generator. It is intended as part of a PWM circuit that
must output constantly OFF for low input voltages and constantly ON
for an input voltage of 5 V.
Specs so far: frequency is about 50 kHz, single supply (5V and 12V
available). Oh, and it must be cheap and built from commonly available
parts, and should not need any adjustment.
I have been trying the "precision triangle generator" of National's
LB-23 with a TLC272 as OP and the LM393 as comparator, with treshold
voltages of 0.2 and 4.8 V. It works ok, however the TLC272 is far too
slow to correctly change the integration direction at the lower
treshold (output very near to negative supply) - at least at 50 kHz...
So the lower edge of the triangle is massively distorted and the signal
not usable in this application.
Other "cheap and common" but faster OPs lack the required output swing
(must be close to the negative supply rail). Modern OPs like the LM6132
are rather expensive...
I also have looked at complete ICs that contain oscillator and/or PWM
comparator (like SG3524, TL494, TL5001, NE555 etc.) - but they all lack
the required precision of oscillator amplitude and thus would require
adjustment. (They are good only in closed loops.)
Any hints welcome, be it fast but common and cheap OPs suitable for this
application, or complete different methods of generating such a ramp or
triangle waveform (or a reliable 0..100% PWM signal for 0..5 V input).
Thanks,
Thanks,
