Hello,
I would like to make 10mm LED light kits running off a 9V DC battery blink in alternating fashion.
I have the basic kits figured out, but I would like to put a very simple 'blink' curcuit board inline with the lights to have them alternately blink.
For Example:
16 LEDs (8 blue and 8 white) are run to the Circuit Board -> wires then go from the curcuit board to the 9V battery and on/off toggle switch. When the toggle is turned on, the 8 blue would turn on while the white were off, then the 8 white would turn on while the blue turned off, and so on and so on... The time can be static at say half a second or 1 full second between flashing. It doesn't matter much and I don't need / want to control the timing.
I know very little about electronics, but I have to imagine such a simple circuit board would be cheap and readily available, but for the life of me, I can't find one online (I probably don't know what to search for).
I would like to avoid creating the circuit board myself and I don't mind buying 100 of them if I have to. Can anyone point me in the right direction to find such a circuit board?
Thanks in advance!
For Example:
Thanks in advance!
