SIMetrix help needed... 'Illegal Device' when using digital models
Chaos Master
I have SIMetrix Intro 4.5.
Suddenly, SIMetrix won't let me use a digital device or a block like
Laplace function. It will tell me that the device is an illegal device.
The error is like:
A$xx [PIN NAMES] [MODEL NAME]
***ERROR***: Illegal device
Q: What can be causing this problem?
[]s
Chaos Master®, posting from Canoas, Brazil - 29.55° S / 51.11° W
"People told me I can't dress like a fairy.
I say, I'm in a rock band and I can do what the hell I want!"
-- Amy Lee
Tim Stinchcombe
The error is like:
Without more information, I don't know how much I can help. Are you placing
on the schematic 'from model library', or 'from symbol library'?; are you
using your own symbols/devices?; have you edited any of the properties,
particularly the 'model' one? - some digital devices are subckts, which are
referenced as 'X$xx' rather than 'A$xx'. I generally find the documentation
sufficiently good to solve most of my problems - you just have to read
diligently! Can you give more info or post a specific example? Failing that,
you could try their support direct - John Warner is very good, and if he's
not too busy may even help despite the fact you only have the 'intro'
version.
Tim
Chaos Master
Tim Stinchcombe stated:
version.
Just found the reason. I had loaded a "broken" SPICE model library,
which caused this.
Looks like the library redefined a few part names.
[]s
-- Amy Lee
