Roger Blake
My Toshiba 19" color TV set (Model CE910) has developed a problem where the
raster is about an inch or so short at the bottom of the screen, leaving
a black strip which cannot be adjusted out. This can be seen here:
http://s291.photobucket.com/albums/ll302/rogblake/tvproblem/?action=view¤t=tvproblem.jpg
The problem occurs no matter what the video source and has actually
gotten a little worse since the above picture was taken. It has
been going on for quite a few years, there is a height control
inside the set and every once in a while I'd just go inside and
adjust it to get the full picture back. Now it's at the point where
the height control is maxed out and the black stripe at the bottom
is creeping up.
On a conventional TV I'd probably check the vertical output tube
for starters, but this is a transistorized set and I'm not quite
sure how to approach it. It actually has been quite reliable over
the years despite the "Made in Japan" label -- aside from occasional
tuner cleanings this is the first repair that has been needed.
(Maybe electrolytic condensers are going bad? The set is about 28
years old.)
Any tips on a possible fix appreciated! (Quips about "buying a new set"
can be sent to /dev/null...)
is creeping up.
years old.)
