I've been working on this integrated amplifier with no left channel and it's turning in to a real head-scratcher. I know that when I first got it that the left channel fuse was blown (250V, 7A, ceramic, Slo blow), so I checked the MOSFETs and found one of the P-Channel, 2SJ162's was burnt. Checking the N-Channel, K1058's some of them were shorted. Not wanting to mess around, I replaced all 8 of the MOSFETs on the left channel. (I actually bought enough for both channels, but haven't gotten that far yet)
I wasn't able to find the exact same model, so I replaced:
2SJ162 with IRFP9240PBF
K1058 with IRFP240PBF
Also, I didn't have enough thermal paste, so I decided to try a Silicone Elastomer. It's an H48-6 and can be found on Digikey here. The only reason that I bring this up is because, after receiving the product and testing it out, I'm not sure if I'm supposed to still have some sort of isolator between the pad and the heat sink. Unfortunately, the phone numbers on the manufacturer's website are for Digikey, and their technicians didn't know either. This is one of those "untested guns in battles" type of situation.
Anyways, I've also checked all of the resistors on the boards with the MOSFETS. There are only four different ones total, and, aside from the 0.27Ohm ones, they were easy to check. My multimeter only displays ohms to one decimal point. Combine that with slight fluctuations between the contacts, and you get unreliable results. I did put a different resistor in line with my test probes to verify that none of the 0.27 Ohm resistors were open or closed however.
I also checked the single diodes on each board and they are good. So are the 1uF caps.
With the left channel unhooked, I get the proper voltage at the connects (+74.5V and -74.5V). However, if I hook up the left channel and try to power the unit on, it makes a buzzing, high current, sound and blows the fuse before I can even power it back off.
I do have the Service Manual/Schematic for this, but, so far, nothing seems out of the ordinary.
Does anyone here have experience with Silicone Elastomer that can verify whether or not I'm using it correctly? Also, any ideas as to what else to check would be incredibly helpful. I'd really like to see this amp working again!
