I am constructing a device that drives a load of about 2.5 Amps. The design involves a pair of MOSFETs and a voltage regulator. According to my calculations it would take 4 voltage regulators in parallel (with load balancing components) with complimentary heat sinks rated at most to 6.2 C/W thermal resistance to drive this circuit without overheating. Along with the MOSFETs, it would mean installing 6 large heat sinks for each TO-220 part. The device requires no moving parts, therefore a fan is not an option.
I am interested in consolidating space by using a single long heat sink instead of 6 individual ones. Problem is I don't know how to calculate the thermal resistance for a shared heat sink like this.
The thermal resistance requirement for the heat sinks are up to 6.2 C/W x 4 and 4.1 C/W x 2. I found a shared plate with a rating of 3.9 C/W that can hold all these parts. Is this good enough? I don't know whether I should average out these ratings or add them together.
Thanks again for your help guys!
