I looked all over the web for information pertaining to this board as to if I could change the I2C address on it. I could not find my specific one so I loaded an I2C scanner sketch and tested what I thought were address jumpers on the back of the module. There are 6 holes in a 3x2 pattern which can accept a pin header or you can simply use a section of 22ga wire to jumper it.
Here is my board:
I will represent the jumpers by brackets. The jumpers are installed in columns. For example: to set 0x24, you will jumper column 1 and column 2.
0x27
0x26
0x25
0x24
0x23
0x22
0x21
0x20
I hope this can help someone else.
Here is my board:
0x27
0x26
0x25
0x24
0x23
0x22
0x21
0x20
