Hi Andreas,
I already have the operation manual but thanks for the info.
Here's my problem:
I see no trace on the CRT. With the beam find button I can see a dot
and can move it with the horizontal and vertical pot.
The time / division knob seems to have no effect. The only position
where I can see something is in the XY mode but it's at the bottom of
the CRT and can't move it from there.
Do you have a clue where I should start looking?
If you have a schematic is it possible to send a scan copy by e-mail?
Denis Cobley said to try the following but without a schematic it's
hard to guess wich wire it is:
Check the TO5 package transistors next to the rear of the CRT - they
often break legs and they form part of the vertical output circuit.
The other thing is to check the vert deflection voltages - you should
see similar on both plates with the position controls in the middle of
their
range.
The other thing you can do is to disconnect the vertical leads from
the CRT
and the trace should centre as the voltages will be similar (both
zero).
Any help or idea is greatly appreciated.
The 2 TO5 transistor have already been replaced in the pass by the
look of the solder. They are currently 2N3866.
Regards,
Benoit
