Wow,I didn't expect so much help. Thank you so much.
I took a while to respond because I wanted to do some more research to
ask less stupid questions (hopefully).
The advice you all gave helped a lot. First I was getting "hung up" on
50 ohms. I assumed the FPGA provided 50 ohm series terminating
resistors for a reason, and that I needed to take advantage of it.
Also I wanted to use a two layer FR4 board to reduce cost (it's my
personal project) but after getting deeper into the layout it became
too much of a burden, so I opted for a 4 layer board. This greatly
reduced the trace width necessary for a particular transmission line.
If I am reading the Cyclone II handbook correctly, the rise and fall
times are 500 ps, giving an electrical length of 144 mm. This means
that, according to this article
http://zone.ni.com/devzone/cda/tut/p/id/3854
, I only need to consider the traces as transmission lines if the
length exceeds about 2.5 cm. That's good to know...
How about some background? I'm trying to build a 900 MHz CDMA
transmitter and receiver, with a 1 Mcps chip rate (actually 1.023
Mcps, more on that later). I've posted a block diagram of the
transmitter here:
http://www.geocities.com/heiligb/LPS/transmitter_block_diag.gif
The schematic diagrams so far are here:
http://www.geocities.com/heiligb/LPS/transmitter_schem1.gif
and here:
http://www.geocities.com/heiligb/LPS/transmitter_schem2.gif
So far there is no useful output from the FPGA, only LEDs and GPIOs
for debugging.
The plan is the FPGA will generate the chipping code, combine it with
the data from USB, and send it to the mixer at zero IF. It is then
mixed up to 920 MHz, filtered and amplified as necessary (haven't done
much design there yet) and transmitted. My plan of attack is to
approach the design incrementally, creating about 5 boards and testing
along the way. Since this is my first high-speed or wireless board
design I believe I'll ultimately save money (and understand the design
better) this way as opposed to creating a full design and having it
not work. The first board will only have the DAC output sent to an SMA
connector. I'm also assuming I'll be able to get my hands on a
spectrum analyzer, high-speed O-scope, etc for testing. Haven't solved
that problem yet.
It seems to me that the requirement for decoupling capacitors can be
summarized as (somewhat tongue in cheek): put a capacitor as close to
the pin as possible. Make the capacitance as large as possible and the
size as small as possible, with a good temperature coefficient,
balancing the cost of the cap.
Here are some highlights from the design so far:
I copied lots of examples from other designs.
I put a .1 uF capacitor on every DC input pin of the FPGA. I don't
know if this is overkill (or underkill?) but it seems like it can't
hurt. The decoupling caps for the FPGA are on page 1.
The decoupling caps on VCCA_PLL1 and VCCA_PLL2 came from an Altera
reference design. Can't figure out why all those different caps would
help, but what do I know?
The LEDs I ordered (Part# 754-1127-1-ND) have a voltage rating of 2.1
volts and a current draw of 20ma. I took (Vcc - VLED) / ILED and found
I needed a 60 ohm resistor. Digikey didn't have one so I got 62 ohms
instead.
I assumed a max of 500ma for 1.2v and 500ma for 3.3v is enough. I put
the jumper there so I can test the current draw in case I assumed
incorrectly.
I'm using only JTAG to program the chip. I ordered a knock-off USB
Blaster from China (hope I don't get ripped off) and hope to get
Quartus II software for a reasonable price.
What's next?
The output of the FPGA will be a square wave at 1 Mcps with no IF. I'm
not convinced yet that I can't directly take an output pin from the
FPGA, send it through a DC blocking capacitor directly to the mixer
(as an analog signal) bypassing the DAC. For this reason I want to
take one pin, terminate for 50 ohms, put a series cap and output it to
an SMA connector. I want to see what comes out on the spectrum
analyzer.
Assuming that doesn't work I will also send data and clock to an 8-bit
DAC (such a waste to have 8 bits when I only need one!). The output of
that will also be to an SMA connector so I can see how it looks.
I've been researching the DAC and I don't know how to pick one. There
are two kinds: current-output and voltage-output. I try to understand
what a current output is and how it is different from a voltage
output, but I can't understand and I can't find any reference. If the
output impedance is constant, then an increase in current will result
in a proportional increase in voltage, right? So then what's the
difference?
Sorry for the long post. Read as much as you like and respond as much
as you like. Again I greatly appreciate your help.
