14 months ago, I was volunteered to be the light string repairer. It took ages to find the dead bulbs or poor connections so I thought 'blow this for a lark' and I placed a 1N4007 in the plug to run the bulbs slightly cooler.
This Christmas one of the strings gave a short flash and died. The string is open circuit.
What would the effect of a diode be? Would the lower temperature give a longer life or the pulses vibrate the filament to destruction?
This technique is used to reduce the heat generated in AC/DC valve radios by using a lower dropper resistor.. Are the filaments likely to suffer?
