Hello, I connected an amperometer to the opposite poles of two 1.5 V batteries not connected in series but there was no current flow, why ? shouldn't opposite charges attract each others ?
thanks
thanks
I can figure out the electrons way when I only use one battery because there is one positive and one negative, but what way they do in two batteries in series ?A battery doesn't create electrons it just takes them from one side and pushes them out the other side (with more pressure, or voltage)
shouldn't voltages be like this ?
there is something I still can't get
Ok but a current is associed with a voltage(your circuit is actually worse than that because your voltmeters are measuring -- in a manner of speaking -- current)
I don't think you get that result unless two voltmeters have the same impedance, do you?
