Serial Data Communication Using Sim 900 gsm module
Hii to Everyone.
This will be my first post as an issue.
First of all i will like to thank the members of electronispoint who are here to support our querries.
I am making a project module in which i am supposed to send the serial data as a text sms to a predefined number over the Gsm module (I have purchased sim 900 module)
I have been successful in recieving the data over the tx line (at 9600 bps) from a serial communication device.
Now the type of data i am recieving over here is alphanumeric.
now my aim is to send these characters to a predefined number using a gsm module.
I am a bit confused in accomplishing my task since i am a new bie in this field.
I am stuck at these points:
1) Do i need a microcontroller for my task.??
2) Do we have an option in gsm module to connect the Tx to Rx directly so that my gsm module can directly recieve the serial data by
eliminating the need of microcontroller...??
3) What type of a circuit will i have to design....????
Any help will be appreciated...
Please reply soon...
Thanks in advance..
Do you have a datasheet for the device?
Perhaps it's as easy as sending some sort of pseudo-Hayes ATxxxxx string to the device?
My apologies Steve.......I dont have a datasheet yet.....
As you mentioned that i have to use the AT commands for my task.....
The issue is ...do i have to use the AT commands from the Module only or do i have to send these AT commands to module by a microcontroller....?
To make it more clear, I would also introduce the breakout board that i am using.
Its available at this link
http://probots.co.in/Manuals/SIM300 Breakout Board - Manual.pdf
In this breakout board we are having four main lines (TX,RX,GND,VCC)
I have in my mind to transfer the serial data from my TX ( The one that i am recieving from my serial communication device) to the RX line of this breakout board.
But unfortunately i am not able to decide as to what interface shall i use to make these both communicate to each other...
what are you viewing the return data on? A PC configured as a terminal?
You could use the PC to drive it. However a microcontroller may be smaller and more economical :)
Yes, i am viewing the serial data on the pc configured as terminal.
But in the real scenario the PC wont be involved anywhere.
Could you suggest which microcontroller would be best for my task and what code shall i write to my microcontroller...
(If there are some important links, that you consider important to me, please let me know)
First question is "Why are you doing this?" Is it for real, or just a school project?
Second thing is... Get the datasheet before you do anything else (not having one tends to indicate to me that this project is not "for real")
Yes, I imagine a uC would be a probable requirement. You may have to look for one with 2 UARTs, or use a bit banging library to allow read/writing via other pins.
I have no idea what your code will eventually look like.
Yes its a final year project.
The project is yet in conceptual phase of development.
Once it reaches the logical phase we will be given the datasheet and
I will for sure upload the same here to get a better understanding of the project.
Is there any specific microcontroller that suits best for my task.
I mean the one that till now, you can gather will be the best for me...:)
Given it's a conceptual phase, I would just say "microcontroller".
You don't know until you get the specs of the device *exactly* how the thing talks. Maybe you'll need something different. You could just pick pic or atmel or anything else you're vaguely familiar with. But I wouldn't pick a particular device. Maybe you could narrow it down to a particular series or family, or maybe to a number of I/O pins and peripherals required -- knowing that this may change slightly.
Thanks for the nice support Steve.
Get me a day or two we are about to get the datasheet (A block diagram)
for the same....:)
I would suggest hooking the micro to the PC so that you can see and debug what you will eventually send the SIM module.
The SCI ports on the micro takes a bit of configuration with speeds and interrupts (at least it does on a HCS12), so this will allow you to have a way of debugging.
You will need some kind of buffer to fill the message once ready the message can be sent byte per byte.
I agree with you that i would have to hook the micro to the PC to see and debug.
But what is the kind of buffer that i would be needing.
How should i add buffer...
Would appreciate if you can suggest me on the usage of buffers...
Any links or some knowledge..
Code for S12 sci / UART
This is some code I've found backed up in my email from 2007 for a project I did with a S12. I can't say this was a working copy. Though I think this will demonstrate some of the complexity with getting getting serial communications working.
/* sci.c
* Author: djm and drk
#include <mc9s12c32.h>
#include "globals.h"
#include "sci.h"
#include <stdio.h>
#include <string.h>
/* Gloabals */
#define MIW ('A')
#define SCI_TIMEOUT (15) // 15 * 20 ms = 300 ms
#define debugSCI (1)
char debug[30];
U_BYTE txBuffer[255]; //FIFO Queue
U_BYTE txBufferInIndex =0;
U_BYTE txBufferOutIndex =0;
#pragma CODE_SEG NON_BANKED
interrupt void sci_isr(void)
SCIInterruptHandler();
PTT = (PTT&(~0x04)) | ((PTT^0x04)&0x04);
#pragma CODE_SEG DEFAULT
void InitSCI(void) /* */
SCIBDH = 0x00;
SCIBDL = 0x1A; // SCI0BDL = 0x1A;
SCICR1 = 0x04; /* Mr Vardons Settings ILT*/
SCICR2 = 0x2C; /* Trial and error from Debugger RIE | ILIE | TE */
//Test
clearTxBuffer();
/* Enable LOOPS for Test*/
//SCICR1 |= LOOPS;
void clearTxBuffer(void)
int i;
for(i =0; i<255; i++)
txBuffer = 'A';
void SCIInterruptHandler(void)
U_BYTE dummyData;
/* Clear Flag*/
if (SCISR1 & (RDRF + OR))
// clear the interrupt flag by reading the status register and
// then the data register
dummyData = SCISR1;
dummyData = SCIDRL;
//Echo
ProcessSCIByte(dummyData);
if ((SCICR2 & SCICR2_TIE) && (SCISR1 & TDRE))
TransmittBufferEmpty();
void TransmittBufferEmpty(void)
U_BYTE dummyData;
dummyData = SCISR1;
if(txBufferOutIndex < txBufferInIndex)
SCIDRL = txBuffer[txBufferOutIndex++]; // Put Byte in SCI Transmitt Register
else
// turn off the transmit empty interrupt
SCICR2 &= ~SCICR2_TIE;
txBufferInIndex = 0;
txBufferOutIndex = 0;
void TransmittMessage(char * message)
int i;
for(i =0; message != '\0' ; i++)
txBuffer[txBufferInIndex++] = message; // Add to Queue
if ((SCICR2 & SCICR2_TIE) == 0) // If Transmitt Empty Interrupt Disabled
SCIDRL = txBuffer[txBufferOutIndex++]; // Service Byte
SCICR2 |= SCICR2_TIE; // Enable Tx Empty Interrupt
Method to buffer Recieved Bytes until full message is recieved.
MIW -> DataLength -> Data -> DataChecksum
void ProcessSCIByte(U_BYTE sciData)
static U_BYTE state = 0;
static U_BYTE dataLength = 0;
static U_BYTE dataBytesRecieved = 0;
static U_BYTE rxBuffer [36];
static U_BYTE rxBufferIndex = 0;
static U_BYTE dataChecksum =0;
static U_WORD timeout = 0;
Will time out messages, not in debug mode
#if debugSCI
if (state > 0 && timer20msTick > timeout)
state = 0;
dataLength = 0;
rxBufferIndex = 0;
dataChecksum =0;
#endif
switch(state)
case 0: //MIW
if(sciData == MIW) // Correct MIW
state = 1;
timeout = timer20msTick + SCI_TIMEOUT;
#if debugSCI
// Debug Message
sprintf(debug, "Valid MIW Found: %c \n\r", sciData);
TransmittMessage(debug);
#endif
else // Incorrect MIW
state = 0;
#if debugSCI
// Debug Message
sprintf(debug, "Invalid MIW Found: %c \n\r", sciData);
#endif
break;
case 1: //Message Length
dataLength = sciData-176; //Conversion from ASCII to Numerical, needed for talking to Hyperterminal.
state = 2;
#if debugSCI
// Debug Message
sprintf(debug, "Message Length is: %d \n\r", dataLength);
#endif
break;
case 2: // Buffer Data
rxBuffer[dataBytesRecieved++] = sciData;
dataChecksum += sciData;
#if debugSCI
// Debug Message
sprintf(debug, "Data is:%c \n\r", sciData);
#endif
if (dataBytesRecieved == dataLength)
state = 3;
#if debugSCI
// Debug Message
sprintf(debug, "Data Complete!!!!\n\r");
#endif
break;
case 3: // Checksum
if (sciData == dataChecksum) //valid message
#if debugSCI
// Debug Message
sprintf(debug, "Checksum Correct!!!! : %d \n\r", dataChecksum);
#endif
else
#if debugSCI
// Debug Message
sprintf(debug, "Checksum Failed!!!! : %d \n\r", dataChecksum);
#endif
//Test
state = 4; // No Break on Purpose
case 4: //Clear Variables
state = 0;
dataLength = 0;
rxBufferIndex = 0;
dataChecksum =0;
break;
thanks a ton for the code....
Although it took me a bit time to consider the code but finally i have got the concept
of buffer from this code....
as it is clear now that we can store the set of characters in the buffer that will then be transfered byte by byte to the sim module....
Just consider a case that we have in our buffer, the values LEFT23-RIGHT33
Now the problem comes that the sim module recognises only the values prefixed by AT+CMGF as its valid commands to send the value as sms.
Like consider the above values in buffer LEFT23-RIGHT33
Since these values have to be sent to a predefined number it means that the following command will have to be issued.
AT+CMGF=1
AT+CMGS="cell number1234"
>value in buffer i.e (LEFT23-RIGHT33)
Now how can we prefix these AT commands to our code in buffer..
Do you have any idea on this....
try sprintf to get the ASCII into a buffer.
No worries with the code. It was only rotting away. best it be put to use.
AT+CMGF=1
I'm a little confused with the example. I have no idea what CMGF and CMGS is?
I think you can just use what you would type out in a terminal with sprintf.
ie. (I'm unsure of the AT commands as above)
char sData[30]; // this may need to be changed to a larger buffer.
sprintf(sData, "AT+61408223344LEFT23-RIGHT33");
TransmittMessage(sData);
I think increasing the buffer could perhaps work in my case....
Let me modify and implement this code and i will keep you updated...:)
These AT commands are the commands to communicate with the GSM module
With CMGF and CMGS are the command arguments...
CMGF- it sets the modem to text mode
CMGS- lets us define a predefined cell number at which the data will be sent....:)
