I'm working on a sequential circuit (256 channels) and my problem is getting each of the channels to send a signal 1 output. The layout consists of 1 master clock (variable from 1Hz to 440Hz), 1 binary (4516) to run the 16 (4067) matrix circuit.
Here is my main question, when each of the (4067) channels go high, I need to have that channel's pulse preset at a single output.
I have a circuit that will pull down the "step between", that gives me the duration of that channel, but when I try to "pulse" the (4067) "inhibit" pin to give me a repeat pulse for that channel, I will not get the circuit to see the changing between the next channel in sequence.
Some notes; when the (4516) runs normal, there is a pulse that will make the (4516) "idol", when it is idol, there is another pulse that will "flash" the (4067)'s "inhibit" input, thus giving me that channels repeat pulse.
