Hello All
Got an issue where I have a PCB that uses the Allegro A4963 IC. I am trying to displace another cheap Chinese JRC per-driver that runs sensored motor, please fin th link here http://www.njr.com/semicon/products/NJM2626.html.
Now, running the same motor (and load) at the same supply voltage the JRC achieves around 52% more speed. (the A4963 schematic is very similar to the demo one as the PDF attached).
I took a trace of the motor phase voltages and note that the JRC sensored driver produces a square wave where the A4963 produces a trapezoidal one. I am guessing that the voltage losses due to being trapezoidal may be the reason for my decrease in speed.
I spoke to the Applications engineers at Allegro and all they can say is that I need to increase the supply voltage or adjust the phase advance (which I tried every value going with no luck).
So, I was hoping one of you had seen a similar issue in the passed and willing to share their knowledge, all traces and schematics are attached (I cant find one for the Chinese driver unfortunately).
PS - Before you mention that the JRC driver uses high side N-channel mosfets that are more efficient, no it doesn't, both drivers use P-channel high side fets...
I cant seem to attached any files, anyone help me with a format? not even PDF goes through without an error...
