So basically, I was going to use my headphones when I realized that the sound had become very noticeably worse. It's hard to say, but I think the sound coming through on the ear opposite to where the lead connects into the headset is fine, but the ear where the lead connects directly into has become much quieter. In some songs the singer could no longer be heard and other instruments had become much louder and it just makes songs so terrible to listen to!
However I discovered that if I hold the jack in the the slot up to the point just before it clicks in, the headphones are then perfect, but once I go past that click it gets worse again. For a short while I used tape to hold it in place where it worked and that was grand but I want to find a permanent solution!
I've cut off the jack and replaced it with a different one and the exact same problem persists so I could only assume that the jack isn't the problem...right??
Any advice on how I could remedy this problem would be very kind of ye because when these headphones are working right they are so lovely!!
