I have an old external hdd power adapter.. which i would like to use as a low voltage bench supply.
Input: 100-240v 1A
Output: 12v 2A / 5v 2A
Now the question is... I would like to max the voltage by connecting both the 12v/5v outputs together to potentially output 17v.. now the question is.. is this actually possible or would the end result.. set the smoke alarm off?! If it doesn't set the alarm off, would i be able to use a buck boost converter to up the voltage further or would i just be better off using one of the outputs for the buck-boost?
Your view and help would be greatly appreciated.
Input: 100-240v 1A
