Don Bruder
A situation I've never encountered, so I've never thought about...
If I've got a 12 volt lead-acid battery, and, for whatever reason, the
charging source decides to start feeding between 6 and 15 volts of AC to
it, what's the most likely result? I'm hoping for something a bit more
useful and specific than "you'll end up with a dead battery" - That's
only too obvious. Should I expect the battery to heat up? Explode? Just
not take a decent charge? Not be affected in any noticeable way? Grow
legs and start dancing the cha-cha? Start reciting Shakespeare?
Something else?
I ask because an ATV we've got here on the ranch appears to be doing
exactly what I described - Depending on engine RPM, the battery
terminals are seeing between 6 and 15 volts of AC. It seems pretty
obvious that the alternator/magneto/whatever-it-is output is going
straight to the battery without regulation or rectification. Trouble is,
doing something about it means putting the machine out of service for at
least a couple of days while we tear the engine down so we can get
access to the regulator/rectifier. (both are INSIDE the engine for some
reason known only to the brain-surgeons at Yamaha) Taking the rig out of
service for more than an hour or two is something that HAS to be avoided
if there's ANY way of doing so.
HELP!!!!
Something else?
HELP!!!!
