G
garyr
I'm trying to build a DDS VFO I've designed. Today I started adding parts to
the board, first the voltage regulator. Voltage OK, 3.301 volts. Then I
added a 50 MHz oscillator (CTS CB3LV); 3.3 volt line now measures 1 volt.
Poking around a bit I find that the VCC and ground going to the oscillator
chip are swapped (the pin numbers I assigned to the package drawing I
created were incorrect). I remove the oscillator chip, make a few cuts and
jumpers and reinstall the oscillator. Lo and behold! it works; sort of. My
scope indicates that the frequency is right on but the output signal is not
a square wave as expected and is much too large - it is now a sine wave
having peak amplitude of positive 5 volts and negative 2 volts. A 200 ohm
load reduces the output amplitude only slightly. The chip was obviously
damaged but what damage would produce that kind of results?
