Milhousesmom . . . . . . . . not using my usual lead in address . . . . just in case you
are a mom . . . .
In reviewing / referencing all case profiles of that regulator . . . . . below . . . .
You are experiencing ground on the suspected REGULATED voltage out on the 1117 ' s center pin.
As for your reference to metering ground, I am suspicioning that your referenced ground circle, as well as the nearby negative pin on that
2 pin molex connector, as well as that card cages massive tinned housing would all be grounded.
Next noticed is that you sure have to plug on a WHOLE LOTTA connectors into that left front edge of the PCB !
How about doing some power down tests with your ohmmeter .
Now I don't know if they are running power to those 4511 drivers from a 12V source or if this 1117 is being either an adjustable unit or is a fixed 5V output.
Since your 1117 units final suffix markings are not using their expected protocol, with some additional 1.8-2.5-3.3-5 numbering also.
You have 12 and 6V on the board, can you confirm which connectors are feeding those voltages in ?
I see two left side connector sets, being referenced as power in and power outs . . .loop throughs, as well as that earlier metioned 2 pin molex near to your GROUND circle.
Also there is a marking on the PCB referring to a barrel power connector and its polarities.
If you use your 0.5V voltage readings, then pin 1 agrees with that pin being in an adjustable mode and connected to some resistors, and not being grounded.
Pin 2 should be your regulated output and NOT grounded .
Pin 3 should be the DC power input to be regulated, with that voltage suspicioned to be 12V.
and not that lowly 1.8 being experienced.
So o o o o o, in a power down condition, ohm from 4511 pin 16 power in and suspect a direct connection to pin 3 of 1117. If that is where the 4511 is being power fed from.
Then ohm from 1117 pin 3, to ground, if its pin 2 is at 0 volt potential, one might expect something pulling that pin 3 voltage down to that low of a value.
And that pin 3 being the HIGHEST voltage present, suggests that it is being the voltage input as per the data sheet, as well as the pin being a voltage adjust, as a voltage presence there suggests, its just that the regulated output . . .pin 2 . . . .seems to be shorted to ground.
I can't make much else out on the board . . .due to it being one of those bastardly black " APPLE" boards.
Can you ascertain if our 2 pin molex connector . . .by plug in . . . .plug out . . . procedure . . .. is being a 12v input or it is outputting 12 v from it ?
73's de Edd . . . . .
