I have oscilloscope Leader LBO 508 A .It worked fine Years ago.Now I wanted to use it again , and when I switched it on, it worked fine , but after some minutes the lines on the screen fade away and it went dark. Next time same but in shorter time , now when I switch it on ,only control lamp went on , nothing on the screen.
I opened it and voltages on testpoints 1 2 3 4 are ok , but on tp 5 (should be -2000v) nothing.
930v ac is present , desoldered and tested diodes D112-113-114-115 : ok .
desoldered and tested hv capacitors c 117-118-119-120-121 : 117 and 119 defective (12pF & 2pF) rest around 500nF=0,5µF.
I want to replace all five but these are oil capacitors MARCON K160DCLU504K not to find in Europe.
What can I use instead ?
Thanks,
Gilbert
Thanks,
Gilbert
