Does anyone know about the reverse breakdown voltage of schottky diodes and how it vaires with temperature. I've done some research and found that the reverse breakdown voltage stated in the data sheet only applies for room temperature and that it should not be used for diodes operating at above this temperature. I guess my question is if i have a diode in a circuit at 60 degrees with a maximum inverse voltage of 50V being applied what would be a safe reverse breakdown voltage for the diode? Is 200V enough to ensure no failures?
thanks in advance
thanks in advance
