Hey Guys, new here. I've got a little project I'm working for my sons room and I need a little help on part of it. I'm going to be putting in a helicopter ceiling fan using an 1:6 Model Helicopter (Little Bird from Ultimate Soldier toy line). Ill be attaching the base of the rotor blades to the bottom plate of the fan so that the fan blades become the props and it looks like a real helicopter. I want to add some scale model LED nav lights to the helicopter so that they go on when you turn the fan on. That being said, I'm still working on getting the exact specs on the nav lights, but they are rated to run on 4.8v-9.0v DC power (not sure on the total amp draw though). Obviously I'm not running DC power in this set up, so I need to run an AC to DC transformer or converter so that the LED controller is getting the correct power it requires. I would prefer not to use a converter that you just plug into the wall, as that would require running a separate outlet on the fan circuit and have both wired to the switch that I'm adding to the wall. Is there a good in-line transformer that I can wire directly into the ceiling fan lights (which are getting removed and replaced with the helicopter) and use that to power the LED controller from there? Below is a link for the nav lights I'm looking at using... Any ideas or input would be much appreciated. Thanks!
LED NAV LIGHTS AND CONTROLLER
https://www.scaleflying.com/Scale-LED-Lighting-System-for-RC-Helicopters-Airplanes_p_17.html
