Saturation in transistors (BJTs) - why and how
KrisBlueNZ
Sadly passed away in 2015
KrisBlueNZ submitted a new resource:
Saturation in transistors (BJTs) - why and how - The reason you would saturate a BJT, and calculating base current and resistor values
When a bipolar junction transistor (BJT) is used to switch a load (e.g. a relay, LED, etc) ON and OFF, it is most often operated as a "saturated switch". This article explains saturation in BJTs - why it is used, and how to calculate the base resistor to ensure saturation.
Read more about this resource...
hevans1944
Hop - AC8NS
At least one reference defines saturation occurring when the base-emitter junction is forward biased and the base-collector junction also becomes forward biased, as a result of the decrease in collector voltage. I think it does no harm to have a little "too much" base current, just to guarantee saturation does occur.... shooting for Vce in the neighborhood of 0.2 V.
KrisBlueNZ
Right, that's the thrust of the resource - that you need "too much" base current.
I mentioned forward-biasing of the base-collector junction as one way to define saturation, but no matter how you define it, there is no clear demarcation between "not quite saturated" and "saturated". Even if you use the base-collector forward bias criterion, I don't think it's right to say saturation "occurs" as soon as any current flows that way. Perhaps you could say it occurs when IBC reaches or exceeds IBE but that's also just arbitrary.
hevans1944
Hop - AC8NS
Yeah, the transition from linear operation to "saturation" is not abrupt. Brute force is the way to go as long as you don't fry the base-emitter junction.
