saturable core modelling in PSpice
Adam M
Hi folks,
I'm trying to create a model of a practical 3-winding transformer - by using
an ideal transformer and adding discrete components to model the losses etc.
I want to create a saturable-core inductor to place accross the terminals of
the primary of the ideal transformer to model the B-H curve.
I've read a bit about how to do this, but everything seems to be aimed at
"SPICE 3", and I'm using PSpice in windows. (I'm a novice!)
What should I do? Does anyone know of downloadable saturable-core inductor
models? Or somewhere else I should go for a tutorial on this?
Thanks in advance!
Adam.
E
Eur Ing John Rye
Hello Adam
Hi folks,
using an ideal transformer and adding discrete components to model the
losses etc.
of the primary of the ideal transformer to model the B-H curve.
If you are a novice, you are taking on a real challenge. I have done some
modelling of iron core devices using Spice 3, and I did not think PSpice is
that different. One approach that I have used successfully for some purposes
is to model the hysteresis loop as two inductors and to switch between the
unsaturated inductance, and the saturated inductance using switches
controlled from a circuit calculating the value of the flux. Applying this to
a 3 winding transformer would be quite interesting.
John
